How to build dynamic SQL based on URL query parameters.
3693
12-12-2019 06:38 AM
BolekBolek
I have an ArcGIS layer published to my local server at:
          https://baseURL/myMapServer/0
I want to dynamically construct the query where clause for this layer based on the URL. For example:
         https://baseURL/myMapServer/0?category=cat1
would effectively translate into the following:
        where category='cat1'
How can I accomplish this?
The arcgsis documentation touches on the topic:
https://pro.arcgis.com/en/pro-app/help/data/query-layers/update-parameter-values-in-a-query-layer.htm
https://www.esri.com/arcgis-blog/products/sharing-collaboration/sharing-collaboration/using-url-parameters-in-web-apps/
https://developers.arcgis.com/labs/arcgisonline/query-a-feature-layer/
Based on this it seems like it would be possible to pass query parameters like this:
      https://baseURL/myMapServer/0/?query=category=cat1
and then refer to them in the definition query:
     category=::category
But it doesn't work, ArcMap throws an SQL syntax error complaining about ::category.
