Find Operation Multiple Search Text Values
3217
07-09-2013 06:24 AM
ChristopherBlinn1
Hello All,
Is it possible to have multiple searchText values in a Find operation?
I would like to search for the occurrence of string1 AND string2 AND ... stringN in a series of fields.
Example:
A user wants to search the value "John Smith".
The layer field has the name stored as "Smith, John".
I would like searchText=John&&Smith (or whatever supported operator exists to specify AND).
I can't seem to find any documentation or examples of anyone doing this so I am lead to presume it is not possible.
Also, I need to use the Find operator, and not a Query(where) so concat (||) fields and building a where statement is not an option.
Any help appreciated!
Chris B.
ChristopherBlinn1
I have solved this by applying a layer definition to the find operation that uses the SQL expression I need to find any matching values.
I split the string entry at each space, and make the search text the first element in the array (arr[0]).
Then I make the layer definition the SQL expression to find matches with the AND operator (field1||field2||field3 LIKE '%arr[0]%' AND field1||field2||field3 LIKE '%arr[1]%' ... AND field1||field2||field3 LIKE '%arr%')
It may not be the cleanest route, but it works like a charm.
Hope this helps anyone else out there looking to do something similar.
Best,
Chris B.
ChristopherBlinn1
Best,
Chris B.
