Field Calculate status returning Error: 400 "Acquiring data task lock failed"
761
05-11-2021 06:16 AM
MGD
I've built an application that uses the calculate method asynchronously on an ArcGIS Online feature service.  Sporadically, I get an error 400: "Acquiring data task lock failed".  I can't find any information on what might be causing this error or any potential work arounds.
Has anyone seen this error before? And are there any known work arounds?
The calculate does work and will calculate records based on the provided where clause until the task lock error occurs.  After the error occurs, no further records are calculated.
