Escape in JSON For Quotation Mark
4459
10
03-13-2019 11:26 AM
joerodmey
I want to pass a quotation mark into JSON but the escape methods I'm using don't appear to be working. How do you pass a strong into JSON with a quotation mark?
        "attributes": {
            "OBJECTID": 307,
            "Comments": "This is a test "with quotes""
RandyBurton
I would try \" :
        "attributes": {
            "OBJECTID": 307,
            "Comments": "This is a test \"with quotes\""
joerodmey
Didn't work. I'm using Integromat push this JSON. Integromat has dynamic data modules that are passed in...don't know if this is causing the issue.
Also, not every time the user will enter quotes in the text box.
JoshuaBixby
MVP Esteemed Contributor
If escaping isn't working, I would try raw string formatting or triple-quoted literals.
joerodmey
Already have Integromat set to RAW body type
JoshuaBixby
For your example, I am talking about Python raw strings or triple-quotes:
>>> print(r'This is a test "with quotes"')
>>> print('''This is a test "with quotes"''')
joerodmey
I'm using JSON
JoshuaBixby
Apologies, I thought this was posted in ArcGIS API for Python‌, not ArcGIS REST API
JoshuaBixby
RandyBurton
The text appearing in the "Value" window  doesn't look like well formed JSON.  It looks like it is a paste inside a previous paste.  If you want "feature" inside the window, it should be in quotes as should "attributes" along with some commas in there.  I would also suspect that the Name should be "features" not "updates".   I must admit, however, that I am not very familiar with Integromat.  To check your JSON, try jsonlint.
