Editing joined featureclass via REST API
1310
07-30-2010 04:57 AM
DaveRabrun
I have 2 feature classes in an MXD. I make the MXD into a featureservice/mapservice. I can query either feature class and edit either featureclass via the rest api.
Now I join one of the feature classes to the other. When I attempt to edit the original feature class, the only value available in the fields page is the objectid, hence all of the attributes i try to pass in through the rest api are ignored.
Is this a bug?
Data Example :
Blocks - ID, Name
Hydrant - ID, BlockID, Name
I Join Hydrant to Blocks so now when i query Hydrant the following fields are available:
Hydrant.ID, Hyrdrant.blockid, Hydrant.Name, Block.ID, Block.Name
This is available in the mapservice.
However in the featuresevice, only objectid is shown as a field.
RaviNarayanan
Dave,
Joined tables are not supported in a Feature Service. The behavior you see for the FeatureService is as expected.
Thanks
Ravi
LuísCardoso
Dave,
Thanks
Ravi
Why this happens?
Is there a workaround to edit feature classes with joined tables using the Rest API?
Thank
Luís (Aveiro, Portugal)
