change mapservice layer's transparence
952
12-01-2011 11:33 PM
zszs
i published a mapservice which has two layers,i need to change the layer's transparence use rest api.
how? or not support?
thanks a lot
zszs
help!!!!:(
SrinivasVinnakota
You cannot change layer transparency at 10.0 and earlier versions using out-of-the box REST API. Support for changing layer transparency will be available at version 10.1.
If you need this functionality then you can create a SOE (ServerObjectExtensions - http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/0001/0001000000zv000000.htm ).
KarenRobine
Hello Srinivas
If I were to use an SOE for this functionality, wouldnt the modifcation of the .mxd layer rendering, or transparency impact ALL users accessing that .mxd through ArcGIS Server? I'm wondering how to do this using an SOE so each user of my ArcGIS Server app would be able to modify their own layers transparency?
