Authoring Annotation feature services in Arcgis Server 10 SP3
5958
01-02-2012 01:27 AM
DarioMatta
The arcgis server help:
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/Authoring_fea...
The following data types are not supported in feature services; annotation.
I have annotation feature class which I want to edit online, there is a future plan (Arcgis 10.1) to allow editing on annotation or I have to change completely approach??
Thanks for your support.
GaryMacDougall
Feature services do not support annotation feature classes. However, if you have annotation in the map that you publish it will be in the map service. You can then draw the map from the map service in your application and edit the features through the feature service using featurelayers in selection mode. That way you get the annontation in the map and can still edit the non-annotation features.
thanks
Gary
KarlWilson
Are there any plans to support this in future?
HILLARYHALL
Yes, image annotation feature services do not support annotation feature classes at present. Thus, if we want to customze and edit annotaiton features, such as annotation font style, annotation font property, font color and size, as well as other annotation parameters, including annotation edge properties in width, style, color, we can only refer to some third party annotation plugin.
