Attachments throw error: Server Error - The remote server returned an error: (500) In
3947
08-17-2012 12:22 PM
JamesLandwehr
When trying to access a REST endpoint with attachments, I am getting a 500 error that reads:
"Server Error - The remote server returned an error: (500) Internal Server Error."
These attachments are stored in a SDE SQL Server database and are served in a dynamic map service using an .msd. They can be opened in the .mxd with no problems.
Any ideas on what to check?
JamesLandwehr
It turns out this was a problem with the arcgisoutput virtual directory pointing to a bad path.
JamesLandwehr
JonGarrido
Hi James,
I've posted two threads of your own about this. How did you resolved this issue?
How cana I modify to correct this arcgisoutput directory??
Thanks in adavance,
Jon
JamesLandwehr
Jon,
In our case, when AGS was installed, we set F:\arcgisserver as the default arcgisserver folder. (i.e. F:\arcgisserver\arcgisoutput) Whenever an upgrade was done, it reset this back to C:\arcgisserver which would not be recognized by the application when looking for the attachments in the F:\ folder. Once I set it back to F:\ the error went away. (You must make sure that the F:\ folder has the correct permissions, etc.)
So, I think the issue in our case was specific to our custom installation of AGS.
Jim
JonGarrido
Thanks Jim,
I'll work on this clue....
