ArcGIS REST Services Directory
1009
08-25-2022 03:52 PM
TundeAina
How does one enable login to view./access ArcGIS REST Services Directory?  Thanks
DavidSolari
MVP Regular Contributor
One thing you can try first is to add "?f=json" to the end of your URL, this should return the resource's JSON definition. I've encountered a lot of ArcGIS Server sites that forbid HTML viewing but are fine with JSON, you might be in the same boat.
JoshuaBixby
Are you asking because you are an administrator or a user?  If you are just a user, or even a publisher, you will not have the privileges to make this type of change.  Also, is this stand-alone ArcGIS Server or federated?
