ArcGIS Online REST calls with Content-type of application/json?
6804
01-08-2015 10:18 PM
VishApte
Hi All,
I have a query regarding ArcGIS Online REST API. We have few AGOL feature services that will be maintained using addFeatures, updateFeatures, deleteFeatures, query and createReplica operations. Feature services are private so token will be passed as parameter using generateToken API.
Most of these REST methods accept parameters and response can be a JSON if format parameter is set to json.
However, REST API does not seem to accept content-type of application/json in the header of the REST request with parameters passed as json object. Using some trial python script below, I discovered only way to pass parameters to REST calls such as generateToken is using application/x-www-form-urlencoded as Content-type.
Same is applicable to response of the REST call. It is always text/plain and not application/json. Is this intended? Using application/json in request and response is much more programming friendly rather than form parameters or plain text response.
Cheers,
Vish
import json
import urllib, urllib2, urlparse
import os, sys
import traceback
def get_response_form(url, query='', get_json=True, exit_on_error = False):
    encoded = urllib.urlencode(query)
    request = urllib2.Request(url)
    request.add_header('Content-Type', 'application/x-www-form-urlencoded;charset=utf-8')
    if get_json:
        response = urllib2.urlopen(request, encoded)
        responseString = response.read()
        json_response = json.loads(responseString)
        if 'error' in json_response:
            if (exit_on_error == True):
                exit()
            else:
                return json_response
        else:
    return urllib2.urlopen(request).read()
def get_response_json(url, query='', get_json=True, exit_on_error = False):
    request = urllib2.Request(url, data=None)
    request.add_header('Content-Type', 'application/json')
    if get_json:
        response = urllib2.urlopen(request, json.dumps(query))
                exit()
            else:
        else:
    return urllib2.urlopen(request, json.dumps(query)).read()
def loginAGOL(AGOLTokenURL, username, password, expirationTime, refererURL):
    print "Generating token using Content-type as application/x-www-form-urlencoded..."
    JSONgenerateTokenRequest = {'username': username, 'password': password, 'expiration': expirationTime, 'client': 'referer', 'referer': refererURL, 'f': 'json'}
    token = ''
    try:
        response = get_response_form(AGOLTokenURL, JSONgenerateTokenRequest)
        if('token' in response.keys()):
            token = response['token']
            print "Generated Token '%s'" %(token)
        else:
            print "Failed to generate token: %s" %(response)
    except Exception, ex:
        error = traceback.format_exc()
        print "Failed to generate token using application/x-www-form-urlencoded: %s." %(error)
    print "Generating token with same parameters using Content-type as application/json..."
    try:
        response = get_response_json(AGOLTokenURL, JSONgenerateTokenRequest)
        else:
        print "Failed to generate token using application/json: %s." %(error)
    return token
def main():
    if len(sys.argv) == 4:
        username = str(sys.argv[1])
        password = str(sys.argv[2])
        expiry = int((sys.argv[3]))
        URLAGOLToken = r"https://www.arcgis.com/sharing/rest/generateToken"
        token = loginAGOL(URLAGOLToken, username, password, expiry, "www.arcgis.com")
    else:
        print "Invalid number of parameters."
        print "Usage: %s <ArcGIS Online username> <ArcGIS Online user password> <expiration time in minutes>" %(os.path.basename(sys.argv[0]))
    sys.exit()
if __name__ == '__main__':
    main()
Tags (3)
HeikoHeijenga
I don't see how things would be easier if content-type would be set correctly, how would the following snippet look like if it was?
data = urllib.urlencode({'username': username, 'password': password, 'expiration': expirationTime, 'client': 'referer', 'referer': refererURL, 'f': 'json'})
req = urllib.urlopen('https://www.arcgis.com/sharing/rest/generateToken', data)
json.loads(req.read())
MuratAkdogan
We also have the same doubt, when esri add wfs:outputFormat=application/json?
