Access to app of Desktop from SOE
1669
6
10-24-2012 08:52 PM
AhadKheirabadi
Hi All,
Is there any way to access to app ( as Iapplication ) of mxd, in the SOE ? I need the app in SOE and I want to get property of it.
Thanks for any help ..
nicogis
AhadKheirabadi
Thank you Domenico  for response,
But my problem is that I develop a SOE service for ArcGIS Server. You can see the related link in this address: http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//0001000000zv000000
In the desktop developing you can access to Application object very easily, but in ArcGIS Server I can't find any way to access to MXD application. I want to read some setting from the mxd application in my SOE service, but I don't know how I can get this object.
RichardWatson
This does not exist in server.  I believe that IApplication is part of Framework and that assembly is only available in desktop:
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#/Overview/00230000010v00...
It would be more helpful if you explain what you are trying to do as there may be another way to do it in server.
AhadKheirabadi
Thank you for your response.
Actually I work on creating a SOE service for doing utility network analyst.
I want to get the network information like barriers, flags, disable layers , etc  from the application and set them to my netsolver and solve the network base on these information. For accessing these information I need to access to NetAnalysisExt and for accessing this extention I need to access to application.In the other word, if I have access to application I can find the networkanalysisExt by CLSID like this code:
pID = new UID();
pID.Value = "esriEditorExt.UtilityNetworkAnalysisExt";
pNetAnalysisExt = (INetworkAnalysisExt)app.FindExtensionByCLSID(pID);
And then I can get barriers, flags, disable layers from pNetAnalysisExt and set to my netsolver and solve the network.
In addition, I try to use FindExtensionByCLSID of SOExtManager but it returns null value:
ESRI.ArcGIS.Carto.IMapServer3 mapServer = (ESRI.ArcGIS.Carto.IMapServer3)serverObjectHelper.ServerObject;
IServerObjectExtensionManager pSOExtManager = mapServer as IServerObjectExtensionManager;
INetworkAnalysisExt NetAnalysisExt = (INetworkAnalysisExt)pSOExtManager.FindExtensionByCLSID("UtilityNetworkAnalysisExt");
Maybe because the UtilityNetworkAnalysisExt in not a valid extension for ArcGIS Server.
So I try to find a way to access to application to get the NetAnalysisExt from that. If it is not accessible, any way that can help me to access to NetAnalysisExt can be very useful.
AhadKheirabadi
Thanks for links. I used them before, it is really good.
