POST method returns a 414 - Request uri too long error when passing complex geometry.
20592
10
06-18-2013 06:25 AM
BobCarberry
I am trying to perform a query operation on a layer in a mapservice by passing in a geometry of type polygon.  The passed in geometry is used to intersect the layer and return the records that the geometry intersected. This works fine for simple geometry however, when I try passing in a complex geometry (one with many vertices, like a curve), I get an error 414 - Request too long.  I am performing this function in a .NET webservice using the POST method for an HttpWebRequest.  What's interesting is if I use the interface on server and copy/paste the geometry string, and clicking POST, it works fine.  Any ideas?
RichardWatson
Put the arguments in body and not the URI.
RichardWatson
BobCarberry
Thanks for your reply, Richard however I believe I am writing to the body, here is my code:
    Private Shared Function PostIt(ByVal baseUrl As String, ByVal input As String) As String
        Dim responseString As String
        Dim request As HttpWebRequest
        Dim response As HttpWebResponse = Nothing
        Dim reader As StreamReader
        Dim byteData() As Byte
        Dim postStream As Stream = Nothing
        request = DirectCast(WebRequest.Create(baseUrl + input), HttpWebRequest)
        ' Set type to POST
        request.Method = "POST"
        request.ContentType = "application/x-www-form-urlencoded"
        ' Create a byte array of the data we want to send
        byteData = UTF8Encoding.UTF8.GetBytes(input)
        ' Set the content length in the request headers
        request.ContentLength = byteData.Length
        Try
            postStream = request.GetRequestStream()
            postStream.Write(byteData, 0, byteData.Length)
        Finally
            If Not postStream Is Nothing Then postStream.Close()
        End Try
        Try
            ' Get response
          '(CRASHES HERE)  response = DirectCast(request.GetResponse(), HttpWebResponse)  '(CRASHES HERE)
            ' Get the response stream into a reader
            reader = New StreamReader(response.GetResponseStream())
            responseString = reader.ReadToEnd
        Catch
        Finally
            If Not response Is Nothing Then response.Close()
        End Try
        Return responseString
    End Function
RichardWatson
What is the length?
Check out the following file:
C:\Program Files\ArcGIS\Server\framework\runtime\tomcat\conf\server.xml
This file seems to define a number of limits for the embedded web server used by ArcGIS Server:
    <Connector connectionTimeout="20000" maxHttpHeaderSize="65535" maxPostSize="10485760" port="6080" protocol="HTTP/1.1" redirectPort="6443" server=" "/>
BobCarberry
The length is 24179. I don't seem to have that file, I'm running Server 10.0.
RichardWatson
Looks like you are putting the information in the URI and in the body.  Right?
BobCarberry
Yes, I think so.
RichardWatson
Take the arguments out of the URI.
Hopefully that should fix your size problem because the size of your URI should be less than 100 characters versus over 24,000.
BobCarberry
Richard,
You are a gentleman and a scholar!  After almost a week of wrestling around with this, your suggestion worked! Thanks!
Here is the solution if any one is interested:
Perform a query on a layer in mapservice in vb.NET using the REST API:
baseUrl = "http://<Server Name>/ArcGIS/rest/services/<Map Service Name>/MapServer/<Layer ID>/query"
input =        "&geometry=" + <geometry> + _
                   "&geometryType=esriGeometryPolygon" + _
                   "&inSR=" + _
                   "&spatialRel=esriSpatialRelIntersects" + _
                   "&relationParam=" + _
                   "&objectIds=" + _
                   "&where=" + _
                   "&time=" + _
                   "&returnIdsOnly=false" + _
                   "&returnGeometry=true" + _
                   "&maxAllowableOffset=" + _
                   "&outSR=" + _
                   "&outFields=*" + _
                   "&f=json"
        request = DirectCast(WebRequest.Create(baseUrl), HttpWebRequest)
        ' Set type to POST
        Try
        Finally
        End Try
        Try
            ' Get response
        Catch
        Finally
        End Try
    End Function
AlanEpp
Bob, thanks for posting your solution.  YOU saved ME a boatload of time and angst!
Al
