How to securely access all sub folder of parent folder using REST API
1983
01-15-2021 02:45 PM
anuragmittal
I want to access all properties of parent folder using Rest API. Its a secured and I am trying to access it though token but not getting any success.
I am following this: https://developers.arcgis.com/rest/enterprise-administration/server/folder.htm
DavidPike
MVP Notable Contributor
More info on your API call and error messages would help.
anuragmittal
Hi David,
I am using PHP curl to access the API. Below is the code. I am getting accessed denied error. Before reaching out to client, I want to know if this is the right approach ?
				if ( !function_exists( "\curl_init" ) )
					\load_curl();
				$curl = curl_init();
				curl_setopt_array($curl, array(
					CURLOPT_URL => "https://xxxxx/arcgis/rest/services/OSvC/OSvC_LandUse_Areas/MapServer?f=json",
					CURLOPT_RETURNTRANSFER => true,
					CURLOPT_ENCODING => "",
					CURLOPT_MAXREDIRS => 10,
					CURLOPT_TIMEOUT => 0,
					CURLOPT_FOLLOWLOCATION => true,
					CURLOPT_SSL_VERIFYPEER => 1,
					CURLOPT_SSL_VERIFYHOST => 2,
					CURLOPT_CAINFO => '/cgi-bin/' . cfg_get((120)) . '.db/certs/ca.pem',
					CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1,
					CURLOPT_CUSTOMREQUEST => "GET",
					CURLOPT_HTTPHEADER => array(
						"Authorization: Bearer ".$token,
						"Content-Type: application/json"
				$response = curl_exec($curl);
				$error = curl_error( $curl );
				$code = curl_getinfo($curl, CURLINFO_HTTP_CODE);
				curl_close($curl);
anuragmittal
Hi David,
My ultimate goal is to get all features layer that are in one particular folder. Let me know if there any other way to doing this.
anuragmittal
 Hi All,
I am able to access the secure folder through browser by manually entering the credentials. But when I try to access it through REST API, I get Invalid Token error.
I am doing the below steps
  1. Generating the token using https://xxxxx/arcgis/tokens/generateToken API
  2. Then calling https://xxxxx/arcgis/rest/services/OSvC/?f=json REST API by passing generated token to access subfolder. But I am getting 'Invalid Token'
VictorTey
Hi,I am not sure how u are passing the token but you can try the following
https://xxxxx/arcgis/rest/services/OSvC/?f=json&token=fdnfdasfdsajffsdfa
