ArcGIS REST API Token Management
1439
08-13-2020 11:37 AM
by Anonymous User
Not applicable
Hello All,
I am building a custom widget for use with the Web AppBuilder and it will be using the REST API.  I am struggling with how to manage the token once it is acquired.  My logic thus far is that the widget will get a token when it is initialized.  Where I am stuck is: a) how to check for an expiration, b) when to check for an expiration.  I thought about getting a new token with every request, but that doesn't seem right.  What is the strategy for token management?
Thank you.
HarishPalaniappan
Hi Damon DelNegro,
Since your code/app is generating the token in the first place, you can set an expiration parameter. If not set, by default tokens generated have expiration of 60 minutes.
If you are using ArcGIS JS – IdentityManager – it has generateToken method – here’s the link
https://developers.arcgis.com/javascript/latest/api-reference/esri-identity-IdentityManager.html
If you have any additional questions please feel free to contact us.
arcgis-insight‌ arcgis rest api
HarishPalaniappan
Hi Damon DelNegro,
