Is it possible to populate list of values for the app user to select one among them as input
673
11-10-2019 08:52 AM
MapDivision
The idea is to restrict the user to concentrate the specific list of predefined area which are allocated to him to work with. Instead of allowing the user to feed the input, is it possible to derive the input values from database itself for each user as per his allocated area units.
IsmaelChivite
Esri Notable Contributor
HI Arockiasamy Lazar‌.  Yes, it is possible.  For details, check the syntax for your User Input at Configure a project—QuickCapture | Documentation  The domain JSON definition is the same as you will find it in a feature service, so if you already have a domain in a feature service you can simply copy and paste it into your User Input.
IsmaelChivite
