By default, the QuickCapture modules in Integromat will connect to ArcGIS Online, but you can also make Integromat work against your own instance of ArcGIS Enterprise.
Before we start, it is important to highlight that Integromat needs to communicate with your own ArcGIS Enterprise instance, and this will not be possible if ArcGIS Enterprise is running completely behind your firewall. You need to make your ArcGIS Enterprise instance is available to Integromat over the internet. ArcGIS Enterprise administrators are familiar with this concept, which is often resolved by exposing ArcGIS Enterprise through a reverse proxy in the DMZ, although there are other options.
A second step, involves explicitly registering Integromat as an app in your ArcGIS Enterprise instance. This step is necessary for Integromat to be able to securely authenticate against your ArcGIS Enterprise. Follow these steps:
All the above is necessary for Integromat to be trusted before you can initiate a secure connection to your Enterprise instance.
Now, it is time to create a new Connection within Integromat to your ArcGIS Enterprise instance. While adding a new web hook using the Watch Project module, choose to create a New Connection:
You will be able to re-use this connection again and again when creating new web hooks.
NOTE: That Integromat has been re-named Make. However, these steps will still work.
