What's new in ArcGIS Production Mapping (March 2023)
719
03-13-2023 11:22 AM
jos20
by Esri Contributor
At ArcGIS Pro 3.1, the ArcGIS Production Mapping extension's product data files include new tools and enhancements.
The step in a workflow that opens a map can be configured to clip the map and its data to the job AOI. This means less data to handle, which requires less processing power. Jobs run in the background are also now prioritized.
When it comes to generalization, the following is a list of what is new:
  • There is a new tool to increase a polygon’s area.
  • There is a new tool to extend a polygon’s sides.
  • There is a new Thin Features tool that enhances the way points are clustered.
  • Different thin tolerances can be specified for the General Point model.
  • When converting polygons to points, you can specify the building angle on the point.
  • When thinning buildings, you can thin different tolerances based on the distance from a built-up area.
  • How the built-up areas are aggregated has been improved.
Keep on the lookout for more content involving workflows and generalization soon!
Contributors
