Domains in hosted Feature Layer do not populate in filtering options
Hi All, I have a domain list for a layer on a hosted Feature Layer. The values all populate as per the coded domain and the label is displayed in the data. However when I try to filter based on the coded domain around half of my coded domains do not display. I tried deleting the domain and readding but nothing will reset.…
Make Administrative Report formatting compatible with publishing to ArcGIS Online
The ArcGIS Online Administrative Reports provide a great snapshot of resources and activities in your organization. In order to build a historical record, it can be helpful to combine reports over time. One way to do that is to publish an initial report's CSV file as a hosted layer on ArcGIS Online, and append subsequent…
Map Viewer - Configure Editing button unresponsive
We've experienced this since Wednesday where the Configure Editing button on Map Viewer is unresponsive on almost all of our maps. It has only worked on a very recently created map, but it won't work on all of our existing templates. Is this behaviour experienced by other users? I wondered if it had to do with the latest…
Enable Z Values even after a hosted feature layer is published
Allow the toggling on of Z-Values after a hosted feature service is published. We have ran into the same scenario a few times when other entities sent us data to publish and the Z-Values where not enabled and we found out after we had the data published and took some surveying shots. To enable the data you have to bring…
Are offline map downloads blocked when an account has a negative credit balance?
This discussion was created from comments split from: Welcome to the New Esri Community!.
Code sharing website link gone
One of the most important things I have come to appreciate in my GIS career is the sharing of code and tools. ESRI use to have an amazing arcscripts website which was replaced by the code sharing site when AGOL took off. ESRI have systematically made accessing this important resource more difficult over recent years. They…
The ArcGIS Data November 2026 Release Is Here!
We’re rolling out new updates to help organizations work with the most accurate location data. This release brings: * Premium imagery is now easier to discover with Content Store for ArcGIS * Google Photorealistic 3D basemap (preview) increased availability * Net new demographics variables for Colombia, Ecuador, Panama,…
ArcGIS Online sharing changed to owner after every ETL run
We work Distribution Collaboration ETL runs that maintains our feature layer. We are recently facing issues with sharing options in ArcGIS Online reverts to Owner every time there's an update. If anyone has faced something similar with Distributed Collaborations?
AGOL Update (November 9, 2026) affected "Create view layer" option of hosted layers?
Yesterday, I created several views in a row from a hosted feature layer in AGOL. This morning I needed to create some additional views of the same hosted feature layer. I was able to create 1 view this morning and then when I tried to create the next one, the "Create View" screen would not proceed past the initial map of…
Expand control of how content is displayed in legends
I think it's high time that legends see some expanded custimazation. One simple tweak that would be much appreciated is not placing the name for an expression/field that is applied to the layer's style in the legend. In the example I have a number of layers with expression's applied so that multiple fields can be used in…
Back up content work project Question
Hi, It has been a while since I last use AGOL to do some of my projects there… The only problem is is there a backup the contents save to PC ? What is the easy way to do ? I need to return to my AGOL content to clean it up .
ArcGIS Online: Easier Access to Zoom to Feature Button
Hello, Many users in my organization utilize ArcGIS Online (AGOL) to review attribute tables and data on a web map. Previously, the zoom to feature button lived on its own in the top area of the attribute table viewer. Now it is hidden behind the three dots options menu. That can add up to a lot of extra clicks. Could the…
ArcGIS Server / Portal Feature Service behind Azure App Proxy - add the service to ArcGIS Online
Hi GIS gurus, I have access to an ArcGIS Server and Portal which sits behind an Azure App Proxy with passthrough disabled. This means only an Entra ID authenticated user (myself) can access the REST endpoints / URL via a browser interactive sign-in. After sign-in - the tokens for pre-auth and authorization are stores as…
Allow item-specific create, update, and delete for OAuth app credentials
When I create or edit OAuth 2.0 developer credentials (app authentication, private application) in ArcGIS Online, "Grant access to specific items" lets me select up to 100 owned items. The "Create, update, and delete" privilege is not offered in that mode. It appears only under "Grant item access using privileges," where…
How to change displayed feature name in legends
I'm struggling with having a feature alias being displayed in the legend of a map. I checked the attribute table for the feature layer, and it says that the alias for the field is set to Magnitude, however it is showing up as "mag" (the fields actual name from the table). Does anyone have a fix?
Edit Related Records For Many-To-Many Relationships
Hi, I have 2 data tables which I created a many-to-many relationship class with ArcGIS Pro and published to ArcGIS Online. There is an intermediate table associating the 2 tables together. I want to be able to select a record from either table within Map Viewer and be able to add a record so I can connect records from both…
Allow historical credit usage reports for feature storage to be segmented by member.
We are trying to generate a credit report for our site that shows the historical feature storage credit usage of the last year for each member of the organization. It seems when the credit report is created, it designates all feature storage credit usage to the administrative account. We would like the feature storage…
ArcGIS Online updates on November 9th. Early Access is open today
We're planning an ArcGIS Online update on November 9, and the Early Access Community is now open. Try new features before they're released, share feedback with the product team, and discover how upcoming enhancements can support your GIS, data, and administrative workflows. Join the Early Access Community:
Admin tools for storage credit usage and Data Store limits.
I’m the admin for a large edu ArcGIS Online Org and like a lot of other edu orgs we’re now in the crosshairs for resolving a file storage and storage credit usage issue that we have no way to directly control. I’ve just seen the latest release demo for the next version AGO and all I see in the way of new admin tools are…
Z-values post-feature layer creation
Good morning, Is there any way to enable Z-values after a feature layer has been created? I already have dedicated Z-value feature layers that I enabled when creating them, but was wondering if it's possible post feature layer creation. It would be helpful for certain feature layers that I initially created when we first…
ArcGIS Online-Item Details Page- Item Dependancy- Basemaps should not show up as maps
Hi ArcGIS Online Team, We recently noticed with the new Item details page's Item Dependency that all basemaps in the basemap gallery show up as items in this dependency Because of this, it makes it extremely difficult to see/find the main map that is being used. We're mostly noticing this on Instant Apps- I'd like to…
Editing multiple features w/ Contingent Values
Ran into this little alert this morning when attempting to do a mass attribute edit on a feature layer that I have enabled contingent values for. The addition of contingent values and multiple feature editing is great and has been something I've been waiting for years. However, I needed to do a mass edit on a single…
creating point features from published table
We are moving our Enterprise system to ArcGIS Online (only, not hybrid). We curently use SQL views as event points in our maps to see currently locations of activities (our activity arrangement table includes lat/long values). I want to have the same in Arcgis Online. I published our SQL table through arcgis Pro to our…
Field descriptions in ArcGIS Server service metadata don’t appear on the ArcGIS Online item that references the service
Background We publish map services from file geodatabase feature classes to a standalone ArcGIS Server and reference them as items in ArcGIS Online. We want our layers ready for Esri’s GeoAI and natural-language features, which rely on field descriptions. Hosted feature layers support these, but moving to hosted isn’t an…
Support for OGC-Compliant WFS 2.0 Services Without GeoJSON Output in ArcGIS Online
Description Currently, only WFS 2.0 services that support GeoJSON output can be added to the ArcGIS Online Map Viewer. This limitation is documented in the product documentation. As part of a project, the following ALKIS WFS services provided by the Landesbetrieb Geobasisinformation Brandenburg (LGB) needed to be…
