December ArcGIS Pro Shorts
740
12-24-2024 09:12 AM
CaitlynNorth
Here are the ArcGIS Pro Shorts we put out this December! These videos contain some of the exciting enhancements made in the newest release of ArcGIS Pro.
Learn how to share 3D tiles layers from ArcGIS Pro to ArcGIS Enterprise.
https://mediaspace.esri.com/media/t/1_gmel7zqq
Starting in ArcGIS pro 3.4, you can create a definition query based on an active feature selection in a map or a scene. This query can be further edited from the layer properties.
https://mediaspace.esri.com/media/t/1_v5punzkr
Enhancements have been made to Paste Properties in ArcGIS Pro 3.4. You can now choose to paste subsets of properties such as symbology, labeling, charts, display filters and more.
https://mediaspace.esri.com/media/t/1_twi5qjqf
Starting in ArcGIS Pro 3.4 you can control the visibility of individual layers symbolized with Unique Values symbology. Toggle checkboxes to control which classes are drawn on the map.
https://mediaspace.esri.com/media/t/1_u1c1eaee
Make sure neighboring areas are never symbolized with the same color by using the Calculate Color Theorem Field tool. This functionality is new in ArcGIS Pro 3.4.
https://mediaspace.esri.com/media/t/1_3shtn2we
Staring in ArcGIS Pro 3.4 you are now able to create combo charts to combine bar and line series into a single visualization. This can also include a secondary y-axis to compare datasets with different scales.
https://mediaspace.esri.com/media/t/1_h77ybw1q
Learn about enhancements to profile graphs, new in ArcGIS Pro 3.4.
https://mediaspace.esri.com/media/t/1_sak9j9wt
Starting in ArcGIS Pro 3.4, administrators can set a custom limit on the amount of time an ArcGIS Pro license can be taken offline. Learn how to set this value as an administrator and check out an offline license as a user. This functionality will be available with the November ArcGIS Online release.
https://mediaspace.esri.com/media/t/1_ebnibt4w
Hyperspectral imagery is now supported starting in ArcGIS Pro 3.4. Learn how to add hyperspectral imagery and use tools.
https://mediaspace.esri.com/media/t/1_4728wf3k
Stay tuned for the January 2025 Shorts wrap up!
