What is the suggested approach to edit branch versioned data in ArcGIS Pro SDK in C#
1174
07-04-2024 06:17 AM
sai_phaneendra
So far I have been working with Traditional versioned database and I am connecting to the geodatabase directly and use EditOperation to complete the edits.
Now I have to get it to work with a Utility network database which is branch versioned. What is the suggested approach to make the edits.
Would the EditOperation work or do I need to complete the edits through a REST API. If so, any references or snippets would be helpful.
Also, if there are some tables in the database that are not versioned, could they still be edited with EditOperation or would that cause any kind of issue with locks on the database ?
Thanks to the community!
GKmieliauskas
EditOperation works with branch versioning.
If you work with default version then set EditOperationType to SHORT, for named set to LONG. Avoid mixing short and long edit operation types.
More info here
sai_phaneendra
Thanks for your response @GKmieliauskas.
Thanks for confirming that the EditOperation works.
Would it be any different if the EditOperation is performed on a featureclass with a direct connection to Geodatabase compared to whether the Edit operation is performed on a map member added as a web service ?
GKmieliauskas
There is no difference from coding side except cases I mentioned earlier.
