Unable to load ArcGIS.Desktop.xxxxx namespaces in v2.5
1117
02-09-2020 07:53 PM
SreenivasaRaoPigili
Hi Team,
    We have developed a solution on v2.4 and which was working very good. I have updated to v2.5 and from then i am facing below errors.
When i checked in my installation directory(C:\Program Files\ArcGIS\Pro\bin)  - i am able to find these dlls (with 01/14/2020 date.)
Is there anything else - we have to do the configurations. Please help me.
FYI: Still same solution is working properly on ArcGIS Pro v2.4.
Wolf
by Esri Regular Contributor
ArcGIS Pro 2.5 requires the .Net Framework 4.8.  Once you change the target framework of your project to 4.8, the errors are resolved.  Details are documented here: https://github.com/esri/arcgis-pro-sdk#requirements
KokiKUNIHARA
Hello SreenivasaRao!
Have you done this yet? If you haven't, I think this is causing the trouble.
How To: Convert a version 2.0 to 2.4 ArcGIS Pro SDK add-in solution to Pro 2.5 and later versions
Wolf
