Smoothing in Raster Mosaic Dataset
1565
01-17-2022 04:23 PM
JoeMadrigal
I'm trying to create an animation of several of my raster datasets by creating a Mosaic Dataset and adding my rasters to that dataset and then adding a time field so I can animate through each.  The problem I'm having is that the rasters seem to have some kind of smoothing or outline around each of the cells:
Any idea how this is happening?  Or is there another suggestion for animating between different raster datasets?
Prashant_MukeshMangtani
Joe,
Click on the mosaic layer in the Contents pane then click on Appearance tab->Resampling Type dropdown. Change the resampling type to Nearest Neighbor and this should produce the same results as the original.
Please let me know if you have any questions.
-Prashant
Joe,
-Prashant
JoeMadrigal
Ah yes!  Thanks!  That is what I was looking for.
Joe
