ProjectionTransformation wgs84
3537
09-30-2015 10:26 AM
nicogis
if I write projection trasformation using wgs84 the create method crash. If I use another sr != 4326 the create method is OK. Is a bug?
  SpatialReference sr4326 = SpatialReferences.WGS84;
  SpatialReference sr3857 = SpatialReferences.WebMercator;
  ProjectionTransformation projTransFromSRs = ArcGIS.Core.Geometry.ProjectionTransformation.Create(sr3857,sr4326);
CharlesMacleod
Hi Domenico, this is definitely a bug. Thanks! We will fix at 1.2. "projTransFromSRs" should be returned but, of course, its Transformation property will be null in this case.
Note: "==" is not overloaded so the false is because the SRs are not the same instance. Please use "IsEqual".
Said another way:
var sr1 = new SpatialReferenceBuilder(SpatialReferences.WGS84.Wkid).ToSpatialReference();
var sr2 = new SpatialReferenceBuilder(SpatialReferences.WGS84.Wkid).ToSpatialReference();
sr1 == sr2 //False!
sr1.IsEqual(sr2) //True!
CharlesMacleod
Said another way:
sr1 == sr2 //False!
