No event for a map being added to a Project
1067
06-05-2020 11:02 AM
DavidLaMartina
In a custom Add-In, I have a method I want to call both when a Map is removed from a Project, as well as when a Map is added. There is a clearly defined event for the former - MapRemovedEvent - which we're using. I don't see an equivalent, e.g. MapAddedEvent. The closest thing I've found is MapViewInitializedEvent, which technically works for our purpose, but it's also going to cause unnecessary method calls when a user opens a tab for a previously created Map.
If there is no map added event, are there plans to add one in 2.6 or later?
Wolf
by Esri Regular Contributor
You can use the Observable Collection of Items (which includes maps) of the Project class: ArcGIS Pro 2.5 API Reference Guide   in order to listen for change events.  Make sure to check that the added/removed item is a Map since folders, layouts, etc. are all Project Items.
CharlesMacleod
David, in addition to Wolf's suggestion, please see the below event. The ProjectItemsChangedEventArgs will tell you what the change is (map added, removed, layout added, removed, etc,etc) via its Action and ProjectItem properties.
ArcGIS.Desktop.Core.Events.ProjectItemsChangedEvent
