Is there an ArcGIS Pro SDK equivalent to ESRI.ArcGIS.ArcMapUI - IDocumentEvents_OnContextMenuEventHandler
536
03-14-2023 06:57 AM
JustinLovato
I need to access events that occur in my map. Previously in ArcMap, using interface IDocumentEvents_Event I was able to override ESRI's stock right-mouse-menu with a custom context-sensitive menu. A different menu was displayed depending on the TOC feature layer that was right-clicked on in the map.
Since ArcGIS Pro does not support MXD files, is there another way of handling context-sensitive menus. Does it make a difference if the layer is a File Geodatabase Feature Class versus a Shapefile Feature Class?
