Is it possible to use geoprocessing management.MakeFeatureLayer?
315
12-09-2025 11:49 PM
RadekMandovec
In ArcObjects, I commonly used MakeFeatureLayer to create a layer from a Feature Class, which I then worked with further, for example for spatial selections. When I try to do the same thing in ArcGIS Pro, I get the following error message: ERROR 000732: Selecting Features: Dataset Extent_lyr does not exist or is not supported.
    await QueuedTask.Run(async () =>
        string pathToFgdb = @"C:\ISSMD\Temp\Masking.gdb";
        string nameExtent = "Extent";
        string nameMasks= "Masks";
        string pathToFcExtent = Path.Combine(pathToFgdb, nameExtent);
        string pathToFcMasks = Path.Combine(pathToFgdb, nameMasks);
        var layerNameExtent = nameExtent + "_lyr";
        var layerNameMasks = nameMasks + "_lyr";
        var args1 = Geoprocessing.MakeValueArray(pathToFcExtent, layerNameExtent);
        IGPResult result1 = await Geoprocessing.ExecuteToolAsync("management.MakeFeatureLayer", args1, null, null, null, GPExecuteToolFlags.AddToHistory);
        var args2 = Geoprocessing.MakeValueArray(pathToFcMasks, layerNameMasks);
        IGPResult result2 = await Geoprocessing.ExecuteToolAsync("management.MakeFeatureLayer", args2, null, null, null, GPExecuteToolFlags.AddToHistory);
        IGPResult result3 = await GeoProcesy.GeoprocessingovaUlohaVysledek("management.SelectLayerByLocation",
                [layerNameMasks, "INTERSECT", layerNameExtent, "", "NEW_SELECTION", "NOT_INVERT"]);
So is it even possible to do it this way or do I have to do it only like this?
FeatureLayer featureLayer = LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerParams, map);
GKmieliauskas
You can use MakeFeatureLayer to create a layer from a Feature Class, but you need to change GPExecuteToolFlags from:
to:
GPExecuteToolFlags.AddOutputsToMap | GPExecuteToolFlags.AddToHistory
ArcGIS Pro geoprocessing without GPExecuteToolFlags.AddOutputsToMap doesn't add layer to map, why your management.SelectLayerByLocation can't find layer from input parameters.
GKmieliauskas
to:
RadekMandovec
thanks a lot. It works:-)
So there is no way to do it without adding a layer to a map?
GKmieliauskas
I don't know another way. You can try to run all your code in Python without using Geoprocessing (call python code from .NET)
