Is it possible to hide or disable the "copy selected rows to the clipboard" button, located in the attribute table? (the id of the button is "esri_editing_table_tableCopySelectedRowsButton").
I have tried to disable it with the OnCanExecuteCommand method but returning false does not do it:
protected override bool OnCanExecuteCommand(string cmdID, string moduleID)
if (cmdID=="esri_editing_table_tableCopySelectedRowsButton")
return false;
return base.OnCanExecuteCommand(cmdID, moduleID);
I have also tried to hide it with the OnUpdateDatabase method, but removing it does not remove it either:
protected override void OnUpdateDatabase(XDocument database)
var nsp = database.Root.Name.Namespace;
var btnElements = from seg in database.Root.Descendants(nsp + "button") select seg;
var elements = new HashSet<XElement>();
foreach (var btnElement in btnElements)
if (btnElement.Attribute("id") != null)
var id = btnElement.Attribute("id").Value;
if(id == "esri_editing_table_tableCopySelectedRowsButton")
elements.Add(btnElement);
foreach (var element in elements)
element.Remove();
ArcGIS Pro 3.1
Thank you
