Incorrect Zoom-to Scale After AddSpatialIndex
641
04-19-2024 12:51 PM
ARO
I'm building an Add-in in ArcGIS Pro 3.2.2 and working on fixing the zoom-to extent after an imported 3D object (.OBJ file) multipatch geodatabase feature class has been moved to a set lat/long/elevation. When the object has been moved, the zoom scale becomes extreme (about the size of Africa) when moved from the original location (0, 0) to France (2, 48). This can be fixed within the ArcGIS UI by using the "Add Spatial Index" geoprocessing tool. However, when attempting to use this tool within the .NET SDK or using ArcPy, the spatial index is fixed, but only after closing ArcGIS Pro and opening the project back up.
public static async Task AddSpatialIndexAsync(string featureClassPath)
try
var arguments = Geoprocessing.MakeValueArray(featureClassPath);
IGPResult result = await Geoprocessing.ExecuteToolAsync("management.AddSpatialIndex", arguments);
if (result.IsFailed)
System.Diagnostics.Debug.WriteLine("Failed to add spatial index: " + result.ErrorCode);
foreach (var msg in result.Messages)
System.Diagnostics.Debug.WriteLine(msg.Text);
else
System.Diagnostics.Debug.WriteLine("Spatial index added successfully.");
catch (Exception ex)
System.Diagnostics.Debug.WriteLine("Error adding spatial index: " + ex.Message);
What's the difference between using the Geoprocessing tool directly and calling the Geoprocessing tool from the .NET SDK?
Aashis
by Esri Contributor
Have you called the map view redraw after the index update?
ARO
Yeah, I've tried that. Here's a list of various attempts at clearing caches, refreshing, and redrawing:
        public static void ForceRefreshLayer(FeatureLayer featureLayer)
            if (featureLayer != null)
                // Toggle visibility
                QueuedTask.Run(() => { featureLayer.SetVisibility(false); });
                System.Threading.Thread.Sleep(100); // Short delay to ensure UI updates
                QueuedTask.Run(() => { featureLayer.SetVisibility(true); });
                MapView.Active.Invalidate(featureLayer, null);
                QueuedTask.Run(() => { MapView.Active.Redraw(true); });
                    var renderer = featureLayer.GetRenderer();
                    featureLayer.SetRenderer(null);
                    System.Threading.Thread.Sleep(100); // Let UI catch up
                    featureLayer.SetRenderer(renderer);
                var dbConnection = Project.Current.GetGeodatabases();
                QueuedTask.Run(() => dbConnection.Refresh());
                var contentItem = Project.Current.GetItems<FolderConnectionProjectItem>().First();
                if (contentItem.IsMainThreadRequired)
                    //QueuedTask.Run must be used if item.IsMainThreadRequired
                    //returns true
                    QueuedTask.Run(() => contentItem.Refresh());
                else
                    contentItem.Refresh();
                    ArcGIS.Core.Threading.Tasks.BackgroundTask.Run(() =>
                      contentItem.Refresh(), ArcGIS.Core.Threading.Tasks.BackgroundProgressor.None);
