I am making a buffer in an ArcGIS Pro Add-in. How do I set the Units?
787
01-24-2020 10:07 AM
SteveScott
I am making a buffer in an ArcGIS Pro Add-in. How do I set the units? GeometryEngine.Instance.Buffer() takes a geometry and a distance. How do I get the map's units so I can choose the metric or US value I give the buffer method?
MichaelPemberton1
Hi Steve,
You may want to look at the ArcGISDynamicMapServiceLayer
Example
private void theArcGISDynamicMapServiceLayer_Initialized(object sender, EventArgs e) {
   // Get the ArcGISDynamicMapServiceLayer.
   ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer theArcGISDynamicMapServiceLayer = null;
   theArcGISDynamicMapServiceLayer = (ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer)sender;
   // Get and display the ArcGISDynamicMapServiceLayer.Units information.
   string theUnits = theArcGISDynamicMapServiceLayer.Units;
   TextBlock_Units.Text = theUnits;
   // Get and display the ArcGISDynamicMapServiceLayer.SpatialReference information.
   ESRI.ArcGIS.Client.Geometry.SpatialReference theSpatialReference = theArcGISDynamicMapServiceLayer.SpatialReference;
   if (theSpatialReference != null)   {
      int theWKID = theSpatialReference.WKID;
      string theWKT = theSpatialReference.WKT;
      if (theWKID != 0)     {
         TextBlock_SpatialReference.Text = "WKID: " + theWKID.ToString();
      else
         TextBlock_SpatialReference.Text = "WKT: " + theWKT;
