How to Zoom a Created Layout's Map Frame to the Last Active Map
854
05-07-2024 02:45 AM
MaxW
After creating a layout, using ElementFactory.Instance.CreateMapFrameElement(lyt, env, map) only displays the entire map view. However, I want to display the scale size that was last presented in the map. How can I achieve this?
CharlesMacleod
To fix the scale of a map on a Layout u need to set a display constraint on the frame. See here https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Layouts#map-frame-display-constraints. Look at fixed scale and fixed center and scale.
CharlesMacleod
MaxW
Thank you, but in the end, I used SetCamera to achieve my goal. I appreciate your suggestion nonetheless. Here's the code snippet:
Camera camera = map_frame.Camera;
camera.Scale = mapView.Camera.Scale;
camera.X = mapView.Camera.X;
camera.Y = mapView.Camera.Y;
map_frame.SetCamera(camera);
