How to use CommandParameter in RelayCommand?
8941
04-13-2021 04:02 AM
TomGeo
In my UI I have multiple buttons to call the OpenItemDialog and I would like to reuse the method to call the dialoge by using the CommandParameter to differentiate the initiating button.
How can I do this using the RelayCommand?
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
Wolf
by Esri Regular Contributor
This community sample shows how to do this:  arcgis-pro-sdk-community-samples/Map-Exploration/TableControlsDockpane at master · Esri/arcgis-pro-s...
In the xaml you can specify the CommandParameter:
<Button Command="{Binding DataContext.TableCloseCommand, RelativeSource={RelativeSource AncestorType={x:Type TabControl}}}"
        CommandParameter="{Binding TableName}" >
TableName in this example is of the type string.
In the code behind you can use the CommandParameter by simple adding 'param' to your RelayCommand as shown here:
public ICommand TableCloseCommand { get; set; }
public AttributeTableViewModel()
  TableCloseCommand = new RelayCommand((param) => OnCloseTab(param), () => true);
private void OnCloseTab(object param)
  // cast the [object] param to the correct type [string]
  string tableName = param.ToString();
  // use your TableName CommandParameter for processing
Wolf
TomGeo
Thanks Wolf, that was precisely what I needed. 👍
