How to specify snap distance parameter using SnapPourPoint GP Tool in ArcGIS Pro SDK?
1490
06-26-2023 07:59 AM
AquanuityDevelopment
The following code with a snap distance of 5 will fail with error code 2147483647.  But if I remove the parameter.  It will be working fine.  Any ideas how to bypass this issue?
string sIputRaster = @"C:\Support\PourPoints.tif";
string sFlowAccumRaster = @"C:\Support\FlowAccumulation.tif";
string sRaterPath = @"C:\Support\Snap.tif";
var parameters = Geoprocessing.MakeValueArray(sIputRaster, sFlowAccumRaster, 5, sRaterPath);
var cts = new CancellationTokenSource();
var results = await Geoprocessing.ExecuteToolAsync("SnapPourPoint_sa", parameters, null, cts.Token,
(eventName, o) =>
}, GPExecuteToolFlags.None);
if (results.IsFailed)
   MessageBox.Show("Failed to create fill layer. Error " + results.ErrorCode);
return;
Tags (1)
GKmieliauskas
As I mentioned in ArcHydro tools question spatial analyst output parameter can migrate. Try specify snap distance after output raster path. In addition check validation messages sent from geoprocessing tool execute.
GKmieliauskas
Thanks a lot, @GKmieliauskas !  After I specified distance after the output raster path, it solved the problem!
