How to clear the payload of OnDragOver method in ArcGIS Pro SDK
1068
05-31-2024 08:04 AM
AbhijeetNandeshwar1
I have created a custom dockpane with two combo boxes. I am implementing Drag and Drop functionality to each combo box. The OnDragover and OnDrop functions work correctly when we use them for the first combo box. How can I clear the payload for the second OnDragover and OnDrop to be used to populate the second combo box.
I tried using dropInfo.Data = null However, it failed to clear the payload for use with the second combo box.
Any inputs would be highly appreciated.
Regards,
Abhijeet
UmaHarano
Do you mean - you want to drop 2 different items into the 2 different combo boxes?
You can implement this in your OnDrop callback in the dockpane.  Something like this:
public override async void OnDrop(DropInfo dropInfo)
   //eg, if you are accessing a dropped file
   if (dropInfo.Data is List<ClipboardItem> clipboardItems) //Dropped from Catalog
	 var thisItem = clipboardItems.FirstOrDefault();
	 var itemInfo = thisItem.ItemInfoValue.typeID;
	if (itemInfo == "database_fgdb") //File GDB
            Name = thisItem.CatalogPath; //binding property for text box control in dockpane
            GDBItems = await GetGDBItemsAsync();
	 if (itemInfo == "cim_map_map") //Map
         MapName = thisItem.CatalogPath; //another binding property for another text box in the dockpane
AbhijeetNandeshwar1
Thank you Uma. I will try to implement the workflow and will let you know if I face any difficulties.
