How to call a Geoprocessing Service using Pro SDK from a custom button
660
03-18-2025 05:43 PM
EstherSmith_Dev
Hi all,
I have a need to call a Geoprocessing service when user clicks a button, wait for the result and show the results. The geoprocessing service is published to a federated server and I can see it in ArcGIS Pro UI's Catalog pane under Portal panel and I can execute it successfully using Pro UI.
I want to do the same programmatically when user click a custom button.
I can see a ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing class and has
ExecuteToolAsync
But it seems to only take the tool name/path as a parameter and not sure if I can pass portal item or a GPServer tool. All examples and snippets in online documentation point to standard tool or a tool from a toolbox. Can someone share a code snippet on calling a GP Service in Pro SDK?
I am trying to avoid making a REST call using http and wait for the jobStatus etc and trying to remain within Pro SDK classes.
Tags (1)
SelimDissem
Hi Esther,
See in ProConcepts Geoprocessing · Esri/arcgis-pro-sdk Wiki · GitHub how to call a Geoprocessing service in Pro
EstherSmith_Dev
Thanks @SelimDissem
My ArcGIS server is a federated server. Do I still need to have ArcGIS Server connection file created? Is it possible to generate AGS file on-the-fly using current Active Portal e.g. ArcGISPortalManager.Current.GetActivePortal() ?
