How to add a locator via sdk ?
1199
20
11-08-2018 07:34 AM
servicesigu
I want to know how to add a locator from a server (ie a geocoding service).
The purpose is to give our users our own locators, when a project is opened.
Thanks in advance for your reply.
Reply
BradNiemand
Jamal,
The way you describe it looks correct.  You are going to want the path to be exactly how it is when you add the locator via Pro.  Just hover over the locator in the Locators folder and you will get the full path.
If you still have issues, I would say it might be time to get technical support involved.
Brad
JamalWest2
Yes it seems to be adding it, but it is just greyed out.
Reply
BradNiemand
Jamal,
When you open the Locate Pane, click on the settings tab and hover over the locator does it give you any type of warning or error?
Brad
JamalWest2
I'm using Version 2.3.3. When I open the Locators menu it if I click the locator it has a red ! next to the Locator I'm attempting to add. Also the folder name isn't there.
Reply
BradNiemand
When you hover over the locator in the settings tab do you get a popup tool-tip with the error message?  If so, what is it?
Brad
JamalWest2
I thought I replied to this earlier. Welp it looks like there is not support for a locator service at this time. Thanks for your help though!
Reply
JamalWest2
One thing I noticed is when I hover over the connection at the end there is an extra '/' so instead of saying /{locatorName}.GeocodeServer it says /{locaterName}.GeocodeServer/
Reply
BradNiemand
I don't see the extra "/" on my end.  What version of Pro are you using?
Brad
JamalWest2
I get "Locator is not available on the current portal."
Reply
NarelleChedzey
Hi Jamal,
Unfortunately, after further investigation, we've found that the LocatorManager class currently only supports local locators and locators shared to Portal.  It does not support locator services.
Thank you for finding this issue.  We will add support for locator services to the 2.5 version of the API.
Narelle
