I would like to programatically set a map to be empty in a mapframe (similar to choosing "<None>" option in a MapFrame). I tried to use mapFrame.SetMap(null) but ArcGIS Pro complains about a null reference object. How do I set the Map to be empty?
When you create a Map frame, if you don't pass in the map, it creates an empty empty map frame.
<SPAN class="keyword token">var</SPAN> mf <SPAN class="operator token">=</SPAN> LayoutElementFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateMapFrame</SPAN><SPAN class="punctuation token">(</SPAN>layout<SPAN class="punctuation token">,</SPAN> mf_envelope<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
I would like to set the map empty in an existing map frame. And that doesn't seem possible.
