How do I get the OK button event in ArcGIS Pro SDK after manually adding a data source to a layer file?
781
03-30-2022 11:34 PM
by Anonymous User
Not applicable
In ArcGIS Pro, I have two layer files that only contain symbology. When we manually set the source by right-clicking a layer, the layer properties window opens, and we enter the path to it in the set Data source field.
After that, we pressed the OK button; does anyone know the function/API for that, so that I can retrieve that path from the backend using C# and populate the table names and their corresponding columns in my TreeView controller?
Thanks in advance!
GKmieliauskas
You need to listen PropertyChanged event on each layer, o layers you want.
                var layerList = MapView.Active.Map.GetLayersAsFlattenedList().OfType<Layer>();
                foreach(var layer in layerList)
                    layer.PropertyChanged += MyLayerPropertyChanged;
        private void MyLayerPropertyChanged(object sender, PropertyChangedEventArgs e)
            // your code here
GKmieliauskas
            // your code here
by Anonymous User
Not applicable
Thanks, it worked perfectly fine for me. 🙂
