How do I change geotiff "no data" color to transparent rather than black using arcpy?
2908
01-19-2022 08:02 AM
ElizabetJaneRoot
Hi Team,
I'm having an issue on having black background on tiff image created by ia.Merge using arcpy.
I want the black part to be transparent just like output data when I use sa.Reclassify(raster, "Value", remap, "NODATA")
Best regards,
Hiroshi
ElizabetJaneRoot
Never mind, I found solution by myself using,
https://pro.arcgis.com/en/pro-app/2.8/tool-reference/data-management/mosaic.htm
nodata_value parameter let you specify a value what to change into NoData and it will make the background transparent
Katie_Clark
MVP Regular Contributor
I had to deal with something similar the other day. What worked for me was going into the symbology pane for the raster layer and changing the value under the "mask" menu:
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
ElizabetJaneRoot
Thanks for the advise @Katie_Clark
However, I would like to know how to do it by using arcpy libraries because I'm building an automation process by python script.
Do you might have any ideas?
ElizabetJaneRoot
Katie_Clark
I'm so glad to hear you got it figured out! And thanks for following up and posting your solution here, in case others reference this post in the future 🙂
Best,
Katie
- Simon Sinek
