How can I get bounding box of features
1922
10-20-2022 10:35 PM
SIASIA1
Hi, I created featureLayer with this code.
string featureClassPath = Path.Combine(Project.Current.DefaultGeodatabasePath, "SIA_" + Data.Data.layer_count.ToString());
var featureClassUri = new Uri(featureClassPath);
var parameters = Geoprocessing.MakeValueArray("./result.json", featureClassPath, "POINT");
var gpResult = Geoprocessing.ExecuteToolAsync("conversion.JSONToFeatures", parameters,
null, CancelableProgressor.None, GPExecuteToolFlags.None);
var layerParams = new FeatureLayerCreationParams(featureClassUri)
Name = job_id,
IsVisible = true,
var createdFC = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
I want to get BBOX(bounding box) of features of FeatureLayer
After getting it, I also want to use bbox to create layer using WMTS.
I know how to get WMTS from url
var serverConnection = new CIMInternetServerConnection { URL = json["Mapbox"].ToString() };
var connection = new CIMWMTSServiceConnection { ServerConnection = serverConnection };
var layerParams = new RasterLayerCreationParams(connection)
Name = job_id,
IsVisible = true,
ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
var layer = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
But I don't  know how to create layer only in range of BBOX
TomGeo
As far as I can see you do not select any features from the newly created feature class, thereby I would aim for the feature layers extend to create the bounding box from it.
Setting the extend of your WMTS layer will mostly require to look into the CIM, although I was lately looking into something similar and couldn’t find a possibility in the api to set an extent for service layers.
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
