How can I add point to line?
1174
09-23-2021 03:39 AM
DavidMrázek
I have a question for you. How can I add points to all lines in the active map? Preferably two points, the first at the beginning and the second at the end of the line.
Thank you very much for your answer and any advice
JayantaPoddar
MVP Alum
I am not an SDK person.
Are you looking to create a Point Feature Class from the start and end vertex of lines?
Then you could use Feature Vertices to Points, where Point Type = "Both Start and End Vertex" (or "Dangling Vertex" if you want the points to be created on open-ends of lines).
Think Location
