Display CIM symbol JSON in .NET ComboBox
2546
12-09-2020 01:46 PM
Douglas_DMeredith
Is there a way to display CIMSymbol, or the raw JSON, as an image in a .NET ComboBox? Or is there a way to export that JSON to a PNG or other image file?
Wolf
by Esri Regular Contributor
Hi Douglas,
 The upcoming 2.7 release has a symbol picker control as part of the SDK.   The symbol picker displays a 'preview' image of the symbol in a listbox (just like Pro does).   Regarding your question: you have a CIMSymbol and want to either display a 'preview image' for that symbol or extract the JSON to display the JSON string?  We have a sample here:  arcgis-pro-sdk-community-samples/Map-Authoring/CustomSymbolPicker at master · Esri/arcgis-pro-sdk-co... that might provide some inside, but if you can describe your desired workflow in more detail i can probably guide you in the right direction.
Wolf
Hi Douglas,
Douglas_DMeredith
That sample helped a lot. SymbolStyleItem has the magic sauce I was looking for. My CIM symbol JSON is kept in a table. Walking the table, I now do this:
CF cf = new CF();
cf.key = row["key"].ToString();
cf.symbol = row["symbol"].ToString();
//Wrap the symbol JSON in CIMSymbolReference, so we can use that class to
//deserialize it.
cf.symbol = cf.symbol.Insert(0, "{\"type\": \"CIMSymbolReference\", \"symbol\": ");
cf.symbol = cf.symbol.Insert(cf.symbol.Length, "}");
//Create the preview image used in the ComboBox
SymbolStyleItem sSI = new SymbolStyleItem() {
	Symbol = CIMSymbolReference.FromJson(cf.symbol).Symbol,
	PatchWidth = 16,
	PatchHeight = 16
cf.preview = sSI.PreviewImage;
And the xaml for the ComboBox now looks like this:
<ComboBox
		x:Name="ContactsAndFaultsComboBox"
		IsTextSearchEnabled="True"
		TextSearch.TextPath="key"
		ItemsSource="{Binding Path=(ui:DataHelper.CFs)}"
		SelectedItem ="{Binding SelectedCF}"
		Margin="0,0,0,5"
		IsReadOnly="False"
		IsEditable="True"
		HorizontalAlignment="Left"
		Height="25"
		VerticalAlignment="Top"
		Width="200">
	<ComboBox.ItemTemplate>
		<DataTemplate>
			<StackPanel Orientation="Horizontal">
				<Image Source="{Binding preview}"  Margin="0,2,5,2" />
				<TextBlock Text="{Binding key}" />
			</StackPanel>
		</DataTemplate>
	</ComboBox.ItemTemplate>
</ComboBox>
Thanks, Wolf!
