Determine whether Enterprise Portal or AGOL
715
10-13-2020 04:09 AM
Vidar
Occasional Contributor II
Is there a sure fire way to discern whether the users logged in portal is enterprise or AGOL?
I thought about a string test against portalInfo.OrganizationId == "0123456789ABCDEF"
which I believe is always Enterprise - but could this value ever change and as a result break my test?
Or there is portalInfo.PortalName which returns "ArcGIS Enterprise" - but could this be changed too?
Anyway if there is someone who knows more than me, I'm all ears
Simon.
Tags (1)
Wolf
by Esri Regular Contributor
You can use either the hostname, name, or the IsPortal flag (true if not AGOL) from PortalInfo:
using this snippet:
protected override async void OnClick()
  try
    var portal = ArcGISPortalManager.Current.GetActivePortal();
    //Force login
    if (!portal.IsSignedOn())
      portal.SignIn();
    //If the sign in failed, this will be the default view of the portal
    var portalInfo = await portal.GetPortalInfoAsync();
    MessageBox.Show($@"hostname: {portalInfo.PortalHostName} name: {portalInfo.PortalName} isportal: {portalInfo.IsPortal}");
  catch (Exception ex)
    MessageBox.Show($@"Error: {ex}");
Vidar
Hi, Can someone from ESRI just give me an idea where to go with this - it would be much appreciated.
Wolf
using this snippet:
  try
    //Force login
      portal.SignIn();
Vidar
Thanks Wolf!
