DAML - add to an existing menu item
837
06-14-2023 10:36 AM
BrianBulla
Honored Contributor
I'm trying to figure out how to add a new menu item to the "Data" menu when right clicking on a layer in the TOC.
The code below will add it to the layers context menu, but doesn't place it into the correct location.  I can't seem to find an ID for the "Data" menu.  I want my new item to appear under "Set Data Source".
	<updateModule refID="esri_mapping">
		<menus>
			<updateMenu refID="esri_mapping_layerContextMenu">
				<insertButton refID="Hyperlink_Button" placeWith="esri_mapping_SetDataSourceContextMenuItem" separator="true"/>
			</updateMenu>
		</menus>
	</updateModule>
NarelleChedzey
Hi Brian,
Try updating the editing module ("esri_editing_EditingModule") and the "esri_editing_data" menu  (or "esri_editing_standalonetable_data_menu" for standalone tables)
This sub menu is inserted into the "esri_mapping_layerContextMenu"
Narelle
NarelleChedzey
Hi Brian,
Narelle
BrianBulla
Honored Contributor
Thanks Narelle...
That works perfectly!
	  <updateModule refID="esri_editing_EditingModule">
		  <menus>
			  <updateMenu refID="esri_editing_data">
			  </updateMenu>
		  </menus>
	  </updateModule>
