Creating a Group with a List of Elements
1016
02-07-2020 12:27 PM
AdamDavis
Creating a group with a list of Elements works OK. If the group's name is changed then all the elements disappear into thin air.
Layout layout = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault()?.GetLayout();
            List<Element> elements = new List<Element>();
            for (int i = 0; i < 100; i++)
                List<Coordinate2D> lineCoordinates = new List<Coordinate2D> { new Coordinate2D { X = i, Y = 0 }, new Coordinate2D { X = i, Y = 100 } };
                Polyline polylineTic = PolylineBuilder.CreatePolyline(lineCoordinates);
                CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlackRGB, 1.0, SimpleLineStyle.Solid);
                GraphicElement lineElm = LayoutElementFactory.Instance.CreateLineGraphicElement(layout, polylineTic, lineSym);
                CIMElement cimElement = lineElm.GetDefinition();
                cimElement.Name = "Line" + i;
                lineElm.SetDefinition(cimElement);
                elements.Add(lineElm);
            GroupElement groupElement = LayoutElementFactory.Instance.CreateGroupElement(layout, elements);
            CIMElement cimGroupElement = groupElement.GetDefinition();
            cimGroupElement.Name = "First Level Group";
            groupElement.SetDefinition(cimGroupElement);
Adam
JeffBarrette
Adam,
Thank you for reporting this.  I can also reproduce the crash when I create the command in 2.4 and use in 2.5.  Again, its a regression and we will address it immediately in 2.6 and hopefully address in a 2.5 patch.
In this case, I get slightly different results if I use .SetName().  The elements don't disappear, they get added to the root level. Similar to another scenario you reported.
Jeff - Layout team
JeffBarrette
This issue was addressed in Pro 2.7
