Clip geoprocessing tool returns a full copy of source raster
739
09-28-2023 11:43 AM
RussellSuter
Hi.
I'm writing a tool for ArcGIS Pro 3.1 that is supposed to clip a rectangle from a raster layer using the management.Clip geoprocessing tool.
var parameters = Geoprocessing.MakeValueArray(layer, envelope, output);
var result = Geoprocessing.ExecuteToolAsync("management.Clip", parameters, null, null, null, GPExecuteToolFlags.None);
The layer is a RasterLayer.  The envelope is a geometry.Extent from the OnSketchCompleteAsync in a custom selection tool.  The output is a .jp2 or .tif output file.
What ends up in the output is a complete copy of the original raster layer instead of the contents of the clipped rectangle.  What am I doing wrong?
GKmieliauskas
One of your geoprocessing tool parameters doesn't match your requirement. Add clipping_geometry parameter with value "NONE". Default value is "ClippingGeometry".
var parameters = Geoprocessing.MakeValueArray(layer, envelope, output, "", "", "NONE");
More info here
GKmieliauskas
More info here
