Change the alias name on table
1658
04-30-2024 06:03 AM
Labels (2)
MariusN
Using ArcGIS Pro 3.2.2.
Is there a way to update the Alias on a "File Geodatabase Table" using the C# SDK?
Have tried to execute the AlterAliasName
string toolname = "AlterAliasName";
string database = Project.Current.DefaultGeodatabasePath;
string inputTable = Path.Combine(database, tabel);
IReadOnlyCollection<string> parameters = Geoprocessing.MakeValueArray(inputTable, alias);
IGPResult gp_result = await Geoprocessing.ExecuteToolAsync(toolname, parameters);
The gp_result.IsFailed is always true and no additional information is given in the response obj.
2 Solutions
Aashis
by Esri Contributor
Yes, you can by using the SchemaBuilder.Modify in the DDL API.
A quick snippet -
using (Table table = geodatabase.OpenDataset<Table>("TableName"))
using (TableDefinition tableDefinition = table.GetDefinition())
  SchemaBuilder sb = new SchemaBuilder(geodatabase);
  TableDescription updateTableDescription = new TableDescription(tableDefinition);
  updateTableDescription.AliasName = "New Alias Name";
  schemaBuilder.Modify(updateTableDescription);
  bool buildStatus = schemaBuilder.Build();
MariusN
Thanks  @Aashis The provided code sample works.
Aashis
by Esri Contributor
A quick snippet -
MariusN
