Textboxes shouldn't be this hard to access. I want to get a few pertinent info pieces from my user for a process and am trying to access some textboxes that I have created on either a pane or a window. Am not able to find a simple way to get the text out of the textbox.
I figured out a way that works for me. In the Dockpane.xaml, add an x:Name= property to the TextBox like this:
<TextBox x:Name="txtWatPolyElev" HorizontalAlignment="Left" Height="23"................
Then in the Dockpane.xaml.cs in the Button_Click method, access the text using the name like this:
string strElev = txtWatPolyElev.Text;
Simple and it works for me.
Hi Sam,
I believe you can add the dock pane at the moment.
You will notice there are two files added into your project *.xaml and *viewmodel.cs
Double click and open the xaml file, you shall replace grid tag with below.
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Grid</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <Grid.RowDefinitions> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>RowDefinition</SPAN> <SPAN class="attr-name token">Height</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Auto<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>RowDefinition</SPAN> <SPAN class="attr-name token">Height</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Auto<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>RowDefinition</SPAN> <SPAN class="attr-name token">Height</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Auto<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>RowDefinition</SPAN> <SPAN class="attr-name token">Height</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>*<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN> </Grid.RowDefinitions> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>DockPanel</SPAN> <SPAN class="attr-name token">Grid.Row</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>0<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">LastChildFill</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>true<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">KeyboardNavigation.TabNavigation</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Local<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Height</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>30<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TextBlock</SPAN> <SPAN class="attr-name token">Grid.Column</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>1<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Text</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>{Binding Heading}<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">Style</SPAN></SPAN><SPAN class="punctuation token">="</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">{</SPAN>DynamicResource Esri_TextBlockDockPaneHeader<SPAN class="punctuation token">}</SPAN></SPAN><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <TextBlock.ToolTip> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>WrapPanel</SPAN> <SPAN class="attr-name token">Orientation</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Vertical<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">MaxWidth</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>300<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TextBlock</SPAN> <SPAN class="attr-name token">Text</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>{Binding Heading}<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">TextWrapping</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Wrap<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>WrapPanel</SPAN><SPAN class="punctuation token">></SPAN></SPAN> </TextBlock.ToolTip> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TextBlock</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>DockPanel</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>StackPanel</SPAN> <SPAN class="attr-name token">Grid.Row</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>1<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Margin</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>5<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TextBlock</SPAN> <SPAN class="attr-name token">HorizontalAlignment</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Left<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Text</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Your text<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">VerticalAlignment</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Center<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TextBox</SPAN> <SPAN class="attr-name token">Name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>txtDebugMessage<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">MinWidth</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>250<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Text</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>{Binding Path<SPAN class="punctuation token">=</SPAN>DebugMessage}<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TextBox</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>StackPanel</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>StackPanel</SPAN> <SPAN class="attr-name token">Grid.Row</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>2<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Button</SPAN> <SPAN class="attr-name token">Name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>btnDisplayMessage<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Command</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>{Binding Path<SPAN class="punctuation token">=</SPAN>CmdDisplayMessage}<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">HorizontalAlignment</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Left<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Width</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>auto<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">></SPAN></SPAN>Display Message<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Button</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>StackPanel</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Grid</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
In your *viewmodel.cs, append the below code.
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">string</SPAN> _debugMessage<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">string</SPAN> DebugMessage <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">get</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> _debugMessage<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">set</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>_debugMessage <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">value</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>_debugMessage <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">value</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">NotifyPropertyChanged</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">private</SPAN> ICommand _cmdDisplayMessage<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">public</SPAN> ICommand CmdDisplayMessage <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">get</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> _cmdDisplayMessage <SPAN class="operator token">?</SPAN><SPAN class="operator token">?</SPAN> <SPAN class="punctuation token">(</SPAN>_cmdDisplayMessage <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">RelayCommand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//Should not use QueueTask with OpenItemDialog</SPAN> MessageBox<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Show</SPAN><SPAN class="punctuation token">(</SPAN>$<SPAN class="string token">"{DebugMessage}"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
