I am trying to use some third party dlls (Entity Framework and EntityFramework.SqlServer) in my arcgis Pro sdk module. However, whenever my code runs inside ArcMap pro, I get errors like this:
No Entity Framework provider found for the ADO.NET provider with invariant name 'System.Data.SqlServerCe.4.0'. Make sure the provider is registered in the 'entityFramework' section of the application config file.
I have several stand alone apps with exactly the same app.config file "entityFramework" section which all work fine:
<entityFramework>
<providers>
<provider invariantName="System.Data.SqlClient" type="System.Data.Entity.SqlServer.SqlProviderServices, EntityFramework.SqlServer" />
<provider invariantName="System.Data.SqlServerCe.4.0" type="System.Data.Entity.SqlServerCompact.SqlCeProviderServices, EntityFramework.SqlServerCompact" />
</providers>
<defaultConnectionFactory type="System.Data.Entity.Infrastructure.SqlCeConnectionFactory, EntityFramework">
<parameters>
<parameter value="System.Data.SqlServerCe.4.0" />
</parameters>
</defaultConnectionFactory>
</entityFramework>
During debug, I can see that the modules have loaded. In my program output I get messages like this:
C:\Users<username>\AppData\Local\ESRI\ArcGISPro\AssemblyCache{05b82a89-759c-4123-b178-75b72b968646}\EntityFramework.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'ArcGISPro.exe' (CLR v4.0.30319: ArcGISPro.exe): Loaded 'C:\Users<username>\AppData\Local\ESRI\ArcGISPro\AssemblyCache{05b82a89-759c-4123-b178-75b72b968646}\EntityFramework.SqlServer.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'ArcGISPro.exe' (CLR v4.0.30319: ArcGISPro.exe): Loaded 'Anonymously Hosted DynamicMethods Assembly'.
Loaded 'C:\WINDOWS\assembly\GAC_MSIL\System.Data.SqlServerCe\4.0.0.0__89845dcd8080cc91\System.Data.SqlServerCe.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
I wonder if anyone else has had a similar problem, if there is some reference or app.config setting I am missing. Or if ArcGIS pro sdk for .Net doesn't read the app.config?
