ArcGIS Pro SDK C#: Copy features from SDE to Project Geodatabase
1785
01-27-2022 10:57 AM
JadedEarth
I'm trying to copy a feature class from an SDE geodatabase into my project's default database but it's not working.  Following is my code in C#:
private async void BtnRun_Click(object sender, RoutedEventArgs e)
    sdePath = TboxPath.Text;
    in_features = TboxInFeature.Text;
    string url = System.IO.Path.Combine(sdePath, in_features);
    Uri uri = new Uri(url);
    string infc = Path.Combine(sdePath, in_features);
    string outfc = Path.Combine(Project.Current.DefaultGeodatabasePath, lyrName);
    await QueuedTask.Run(() =>
	Geoprocessing.ExecuteToolAsync("CopyFeatures_management", Geoprocessing.MakeValueArray(infc, outfc));
Then after I copy it to the default geodatabase, I want to load it as a layer on my active map.
Appreciate any help.
JadedEarth
Found the solution.  Instead of CopyFeatures_management tool, I used FeatureClassToFeatureClass_conversion tool since I'm dealing with two geodatabases.
Below is the solution.  This copies the feature class to the default project geodatabase from a SQL Server geodatabase and displays it on the active map after copying:
    string infc = TboxInFeatures.Text;
    string outputLocation = Project.Current.DefaultGeodatabasePath;
    string outputName = TboxFcName.Text;
    ProgressDialog progDlg = new ProgressDialog("feature Class to Feature Class...", "Cancel", 100, true);
    progDlg.Show();
    IReadOnlyCollection<string> args = Geoprocessing.MakeValueArray(infc, outputLocation, outputName);
    IGPResult gp_result = await Geoprocessing.ExecuteToolAsync("FeatureClassToFeatureClass_conversion", args, null,
                new CancelableProgressorSource(progDlg).Progressor, GPExecuteToolFlags.Default);
JadedEarth
    progDlg.Show();
