Accessing Custom Tool From Within Released Add-In
1455
06-22-2023 12:22 PM
RussellSuter
Hey All,
I have managed to create an add-in for ArcGIS Pro 3.1 that I'm ready to deploy to my user base.  My add-in calls a python GeoProcessing tool which is in my AddIn.esriAddinX file.  The problem is my code can't find it.  I ran across something awhile back that suggested I do something like this:
string here = System.IO.Directory.GetCurrentDirectory();
string script = System.IO.Path.Combine(here, @"Toolboxes\Tools.atbx\BuildGeoPackage");
This worked great while building and running the Debug configuration.  Now though, when building for Release, it doesn't work.  The "here" string references the user's Desktop folder but the add-in is in Documents\ArcGIS\AddIns\ArcGISPro\{uuid}\AddIn.esriAddinX.
How do I get the actual install folder and then once there how do I peek into the .esriAddinX file?
RussellSuter
This appears to work for both Debug and Release:
string here = Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().Location);
RichardDaniels
MVP Regular Contributor
Suggest you place the code on a network share drive, thus you don't have to deploy the python code to every machine. Then the path would be \\myserver\mypythongcode\thecode.py
RussellSuter
That is a nice idea but, for a couple of reasons I won't go into here, I can't do that.
RussellSuter
